The Axminster Magnetic Hose Coupler Rubber Cuffs & Clips are designed for fitting and maintaining Axminster magnetic dust extraction systems. Available in 63mm and 100mm sizes, these replacement components provide a simple way to install magnetic hose couplers onto compatible dust extraction equipment or replace worn parts to keep your system performing reliably. Ideal for new installations, repairs or expanding an existing setup.
Manufactured from durable, workshop-grade materials, the rubber cuffs provide a secure connection between the magnetic coupler and your machine or extraction hose, while the retaining clips hold the coupler firmly in place. Designed for straightforward installation, they offer a reliable fit and are fully compatible with the Axminster magnetic hose coupling system. Select the appropriate size to match your dust extraction equipment.
Bore Size 63 mm
EAN Barcode 5052511146833
