{"product_id":"axminster-set-of-4-drum-sanders","title":"Axminster Set of 4 Drum Sanders","description":"\u003cp\u003eThis set of four, 75mm long  sanding drums will help you get more use out of your pillar drill or woodturning lathe. The drums are a resilient rubber fitted with an abrasive sleeve. Turning the nut located on the base of each drum, slightly expands the rubber and secures the abrasive sleeve. The diameters are: 25.4mm (1\u003cspecial id=\"1\"\u003e\u003c\/special\u003e), 50mm (2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e), 63mm (2.1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) and 75mm (3\u003cspecial id=\"1\"\u003e\u003c\/special\u003e). Partially used sleeves can be removed and kept for use at a later date. The drums come with two sets of sleeves, 80 grit and 120 grit. Replacement sleeves are readily available. Each drum has a 12.5mm shank. Maximum recommended speed 1,500rpm.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54118450331995,"sku":"108513","price":36.54,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/108513_xl.jpg?v=1789780534","url":"https:\/\/www.axminstertools.com\/products\/axminster-set-of-4-drum-sanders","provider":"Axminster Tools","version":"1.0","type":"link"}
