{"product_id":"axminster-single-use-heat-shrink-sleeve-120mm-60mm","title":"Axminster Single Use Heat Shrink Sleeve 120mm-60mm","description":"\u003cp\u003eThe Axminster Single Use Heat Shrink Sleeve offers a simple, permanent solution for connecting woodworking machines to a dust extraction system. Manufactured from durable heat shrink tubing, it creates a custom-fit, airtight seal between your machine and extraction hose, helping to maximise extraction efficiency while preventing air leaks.\u003c\/p\u003e\u003cp\u003eWith an initial diameter of 120mm, the sleeve can be heat shrunk down to 60mm using a standard hot air gun, making it ideal for creating dust extraction adaptors where standard fittings aren't available. Once heated, it contracts tightly around the machine outlet to form a secure, permanent connection that won't loosen over time.\u003c\/p\u003e\u003cp\u003eMeasuring 200mm in length, the sleeve provides ample surface contact for a strong, reliable join, making it perfect for machines that remain permanently connected to a dust extractor. It eliminates the need to source rare adaptor sizes, while removing the need for hose clamps or additional fittings.\u003c\/p\u003e\u003cp\u003eIdeal for wood dust and chip extraction systems, the Axminster Single Use Heat Shrink Sleeve provides a clean, airtight connection that helps keep your workshop running efficiently.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54118849511771,"sku":"114224","price":9.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114224_xl.jpg?v=1789793685","url":"https:\/\/www.axminstertools.com\/products\/axminster-single-use-heat-shrink-sleeve-120mm-60mm","provider":"Axminster Tools","version":"1.0","type":"link"}
