The Axminster Single Use Heat Shrink Sleeve offers a simple, permanent solution for connecting woodworking machines to a dust extraction system. Manufactured from durable heat shrink tubing, it creates a custom-fit, airtight seal between your machine and extraction hose, helping to maximise extraction efficiency while preventing air leaks.
With an initial diameter of 120mm, the sleeve can be heat shrunk down to 60mm using a standard hot air gun, making it ideal for creating dust extraction adaptors where standard fittings aren't available. Once heated, it contracts tightly around the machine outlet to form a secure, permanent connection that won't loosen over time.
Measuring 200mm in length, the sleeve provides ample surface contact for a strong, reliable join, making it perfect for machines that remain permanently connected to a dust extractor. It eliminates the need to source rare adaptor sizes, while removing the need for hose clamps or additional fittings.
Ideal for wood dust and chip extraction systems, the Axminster Single Use Heat Shrink Sleeve provides a clean, airtight connection that helps keep your workshop running efficiently.
