G clamps are an essential assembly tool, perfect for a wide variety of applications. These small G clamps (or C clamps depending which side of the pond you are on) are strong, well made and suitable for a use in wide variety of tasks and trades. They have a slim cross section offering a great advantage where space is limited or where larger clamps are too cumbersome or too heavy. Use them for all sorts of assembly, woodwork, fabrication, model making, welding and more.
They have an excellent size to clamping pressure ratio. In each case, the capacity is equal to the throat depth. The frames are cast iron, with a durable coating to prevent corrosion. The screw thread, swivel pad and tommy bar are plated to resist rust.
Additional Accessories No
Clamping Capacity 25 mm
Clamping Capacity x Throat 25 x 25 mm
Web Attribute Set G Clamps
EAN Barcode 5052511118991
