A replacement, superior rip fence arrangement that will replace the flimsy fences found on many, low cost benchtop bandsaws. This is a very worthwhile upgrade that will make your machine more accurate to use. The fence is 370mm long and the rail 340mm. Some small modification work will be needed to adapt this to most machines, but this should not deter you from making this upgrade.
Axminster Small Rip Fence Upgrade
| Web Attribute Set | Bandsaw Accessories |
| EAN Barcode | 5052511002672 |
