Achieve precise and consistent planer blade installation with the Axminster TC Spiral Cutter Wrench. Designed for woodworking machinery, this tool ensures the exact torque needed for safe blade mounting, reducing the risk of over-tightening, uneven clamping and cutter head damage. It is designed for replacing TC Spiral Cutters.
The compact Tee-handle design provides excellent control and comfort, making it easy to reach blade bolts even in tight or awkward spaces. Set to 6NM, the torque wrench delivers reliable, repeatable tightening every time, removing the guesswork from blade installation.
Made from high-quality, corrosion-resistant steel, this tool is made to withstand demanding workshop environments. The ergonomic, non-slip grip ensures a secure hold during use, while the torque-limiting click mechanism helps protect both blades and cutter heads from excessive force and indicates when the torque is reached.
Ideal for use with thicknessers, jointers, and planers that require precise blade mounting.
Web Attribute Set Planers Accessories
EAN Barcode 5052511144082
