{"product_id":"axminster-thickness-gauge-0-15mm","title":"Axminster Thickness Gauge 0-15mm","description":"\u003cp\u003eA thickness gauge, sometimes referred to as a degree gauge uses the simple device of having a much longer arm on the reading side to magnify any movement from the measuring side of the pivot. Thus a small gap between the tips becomes a much larger swing of the measuring arm and a reading can be taken from a suitably calibrated scale fixed to the opposite leg.\u003c\/p\u003e\u003cp\u003eThis model will measure between 0 and 15mm in increments of 0.1mm and has a throat depth of 20mm. Taking the sharpness of the pointer into account and the effects of parallax you have a great value tool that will give you a reading with far more resolution than anything else in this price range. All steel construction, overall length 155mm.\u003c\/p\u003e\u003cp\u003eOur cycling staff have found this an excellent tool for measuring cycle rims for wear.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54116667097435,"sku":"210970","price":5.95,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/210970_xl.jpg?v=1789761984","url":"https:\/\/www.axminstertools.com\/products\/axminster-thickness-gauge-0-15mm","provider":"Axminster Tools","version":"1.0","type":"link"}
