Machine Wax greatly reduces friction between timber and the surface of machine tables or hand tools. This makes processing much smoother and results in an increase in the quality of the machined surface.
Machine wax is silicone free, apply sparingly to the machine tables and buff with a soft cloth. Its use is of particular benefit on aluminium alloy and cast iron. Used regularly, it also helps prevent corrosion. By lessening friction between the workpiece and machine surfaces, you gain greater control. Always remember to disconnect machinery before applying wax.
N.B. Product label may vary from image.
