Use these felt wheels to produce the ultimate, mirror polished edge. The finest edge you can get on any tool is with a strop or a felt wheel. Made from compressed wool, felt wheels have excellent resilience and are long lasting.
The medium grade felt is a good choice for final edge polishing of both straight-edged tools and tools with gently curved profiles. It gives excellent results on plane irons and carving gouges with wide sweeps. A medium felt wheel is still very firm, but is more suitable for carving tools where a very small amount of deformation is desirable to accommodate a slight curvature.
When the wheel is dressed with a honing compound, the edge obtained is comparable to that of a razor blade. For best results use with Blue Steelbrite, Flexcut gold or Veritas green compound.
Each 100mm diameter x 20mm wide wheel has a 12mm bore for mounting onto the Ultimate Edge 'Twist & Fix' arbor.
Please note that blades should always be presented to the wheel so the edge of the tool trails, i.e. the direction of rotation is away from the tool.
Made in Britain Yes
Web Attribute Set Polishing Mops
EAN Barcode 5052511109494
