{"product_id":"axminster-twist-fix-100mm-felt-wheel-soft","title":"Axminster Twist \u0026 Fix 100mm Felt Wheel - Soft","description":"\u003cp\u003eUse these felt wheels to produce the ultimate, mirror polished edge. The finest edge you can get on any tool is with a strop or a felt wheel. Made from compressed wool, felt wheels have excellent resilience and are long lasting.\u003c\/p\u003e\u003cp\u003eThis soft felt wheel is able to deform slightly, enabling you to hone the edge of tools with tighter curves. Soft is a relative term; as the felt is still firm enough to produce a razor sharp edge as well as adapting to the shape of the tool.\u003c\/p\u003e\u003cp\u003eWhen the wheel is dressed with a honing compound, the edge obtained is comparable to that of a razor blade. For best results use with Blue Steelbrite, Flexcut gold or Veritas green compound.\u003c\/p\u003e\u003cp\u003eEach 100mm diameter x 20mm wide wheel has a 12mm bore for mounting onto the Ultimate Edge 'Twist \u0026amp; Fix' arbor.\u003c\/p\u003e\u003cp\u003ePlease note that blades should always be presented to the wheel so the edge of the tool trails, i.e. the direction of rotation is away from the tool.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54118330958171,"sku":"105578","price":17.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/105578_xl.jpg?v=1789775944","url":"https:\/\/www.axminstertools.com\/products\/axminster-twist-fix-100mm-felt-wheel-soft","provider":"Axminster Tools","version":"1.0","type":"link"}
