{"product_id":"axminster-twist-fix-100mm-looseleaf-polishing-mop","title":"Axminster Twist \u0026 Fix 100mm Looseleaf Polishing Mop","description":"\u003cp\u003eThese 100mm diameter looseleaf mops have a 12mm bore for mounting onto the Ultimate Edge Twist \u0026amp; Fix arbor.\u003c\/p\u003e\u003cp\u003eThese mops consist of layered cotton material left unstitched for a softer working surface. Use these mops with the finest compounds for final polishing and high glossing on steel and stainless steel. They are the mop of choice for first stage and final finishing of non-ferrous metals such as brass and copper.\u003c\/p\u003e\u003cp\u003eFor best results use separate mops for each different compound, mark each mop using a felt tip pen with the type of compound used.\u003c\/p\u003e\u003cp\u003eSold in pairs, both need to be used together when used with the Twist \u0026amp; Fix arbour.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54118327386459,"sku":"105423","price":12.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/105423_xl.jpg?v=1789775755","url":"https:\/\/www.axminstertools.com\/products\/axminster-twist-fix-100mm-looseleaf-polishing-mop","provider":"Axminster Tools","version":"1.0","type":"link"}
