These 100mm diameter nylon abrasive wheels have a 12mm bore for mounting onto the Ultimate Edge Twist & Fix arbor. Each abrasive wheel consists of 4 discs of non-woven nylon, coated with aluminium oxide abrasive. The wheels are versatile and effective. They are available in different grades for rust removal or surface finishing. A certain amount of flexibility means you can use them on curved surfaces.
The fine (green) grade (approx 360g) will impart a satin finish onto the metal surface, which can be a finish in itself or further refined using polishing mops and compounds.
Eye protection must be worn.
Please note that blades should always be presented to the wheel so the edge of the tool trails, i.e. the direction of rotation is away from the tool.
