{"product_id":"axminster-twist-fix-100mm-stitched-polishing-mop","title":"Axminster Twist \u0026 Fix 100mm Stitched Polishing Mop","description":"\u003cp\u003eThese 100mm diameter stitched sisal mops have leather centre washers and 12mm bore for mounting onto the Ultimate Edge Twist \u0026amp; Fix arbor.\u003c\/p\u003e\u003cp\u003eStitching produces a mop with a firmer face; a stitched mop's normal usage is in the first and second (if required) stages of the polishing process. For best results use a separate mop for each different compound, mark each mop using a felt tip pen with the type of compound used. Good results obtained with pink or white compound.\u003c\/p\u003e\u003cp\u003eSold in pairs, both need to be used together when used with the Twist \u0026amp; Fix arbour.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54118327288155,"sku":"105422","price":10.68,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/105422_xl.jpg?v=1789775747","url":"https:\/\/www.axminstertools.com\/products\/axminster-twist-fix-100mm-stitched-polishing-mop","provider":"Axminster Tools","version":"1.0","type":"link"}
