The Axminster Push Block is an essential workshop safety accessory, designed to give you greater confidence and control when guiding workpieces across a wide range of woodworking machines. Featuring a high traction, non-slip base and an ergonomic raised handle, it allows you to maintain steady downward and forward pressure while keeping your hands safely away from blades and cutters.
The durable, non-marring rubber base provides excellent grip on timber, sheet materials and composites, helping to prevent unwanted movement and ensuring a smooth, controlled feed through the cut. A positive trailing-edge support gives you extra driving force and produces cleaner exit cuts, improving control and helping to produce more accurate results with reduced tear-out.
Its stable footprint makes it particularly effective when working with smaller or narrower stock, while the comfortable elevated handle offers a secure grip for precise steering throughout the cut. Finished in a bright, high visibility colour, it's always easy to find on a busy workbench or in the workshop.
Ideal for use on table saws, router tables and other woodworking machinery, the Axminster Push Block is built for dependable everyday performance. For longer or heavier workpieces, use a pair together to maintain consistent control from start to finish, making every cut safer, smoother and more accurate.
Overall L x W x H 195 x 960 x 120 mm
Web Attribute Set General Machine Accessories
EAN Barcode 5052511147274
