{"product_id":"axminster-ultrasafe-push-block","title":"Axminster UltraSafe Push Block","description":"\u003cp\u003eThe Axminster Push Block is an essential workshop safety accessory, designed to give you greater confidence and control when guiding workpieces across a wide range of woodworking machines. Featuring a high traction, non-slip base and an ergonomic raised handle, it allows you to maintain steady downward and forward pressure while keeping your hands safely away from blades and cutters.\u003c\/p\u003e\u003cp\u003eThe durable, non-marring rubber base provides excellent grip on timber, sheet materials and composites, helping to prevent unwanted movement and ensuring a smooth, controlled feed through the cut. A positive trailing-edge support gives you extra driving force and produces cleaner exit cuts, improving control and helping to produce more accurate results with reduced tear-out.\u003c\/p\u003e\u003cp\u003eIts stable footprint makes it particularly effective when working with smaller or narrower stock, while the comfortable elevated handle offers a secure grip for precise steering throughout the cut. Finished in a bright, high visibility colour, it's always easy to find on a busy workbench or in the workshop.\u003c\/p\u003e\u003cp\u003eIdeal for use on table saws, router tables and other woodworking machinery, the Axminster Push Block is built for dependable everyday performance. For longer or heavier workpieces, use a pair together to maintain consistent control from start to finish, making every cut safer, smoother and more accurate.\u003c\/p\u003e","brand":"Axminster","offers":[{"title":"Default Title","offer_id":54118849970523,"sku":"114231","price":39.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114231_xl.jpg?v=1789793764","url":"https:\/\/www.axminstertools.com\/products\/axminster-ultrasafe-push-block","provider":"Axminster Tools","version":"1.0","type":"link"}
