If you have several tools with different sized ports, this extraction adaptor enables you to connect your vacuum hose to a variety of extraction ports with ease. It features a square flange with mounting holes and is made to withstand wood dust and fibres. The mounting section is 69mm and the mounting holes are 3.5mm.
It has an outer diameter of 60mm, inner diameter of 53mm. The outlet can be trimmed down to your desired diameter of 20mm, 28mm, 34mm or 46mm.
EAN Barcode 5052511140787
