This universal machine stand is particularly handy for when you may not have bench space and want to mount your machines as standalone. It provides stability for your machinery and is suitable for most Axminster machines. Use plywood or MDF board to adjust if your machine isn't a perfect fit. The top of the stand is 460 x 610mm, whilst the height is adjustable from 550 - 865mm. Simply use the pre-drilled holes to allow the stand height to be adjusted.
It has a maximum weight limit of 135kg. Please note that a wooden top is not supplied.
Web Attribute Set General Machine Accessories
EAN Barcode 5052511141944
