This is a replacement grinding wheel for the Axminster AW150BG/AC150BG bench grinder and is suitable for many other 150mm grinders. It has a 31.75mm bore that can be reduced using the Axminster grinding wheel reduction bushes.
White Aluminium Oxide grinding wheels are a preferred choice for general tool sharpening of high carbon and HSS tools.
Compared to general purpose grey grinding wheels, white wheels cut much cooler with far less tendency to overheat a tool’s edge (if you press hard enough for long enough you can still blue the edge). These white grinding wheels have a medium hard vitrified bond with a medium structure. They are friable and cut freely offering a fast result and clean finish.
Web Attribute Set Replacement Grinding Wheels
EAN Barcode 5052511124039
