White Aluminium Oxide grinding wheels are a preferred choice for general tool sharpening of high carbon and HSS tools.
Compared to general purpose grey grinding wheels, white wheels cut much cooler with far less tendency to overheat a tool’s edge (if you press hard enough for long enough you can still blue the edge).
These white grinding wheels have a medium hard vitrified bond with a medium structure. They are friable and cut freely offering a fast result and clean finish.
The wheels have a 5/8 bore
Grit 80
Wheel Diameter 200 mm
Wheel Width 25 mm
Web Attribute Set Replacement Grinding Wheels
EAN Barcode 5052511120611
