Axminster Woodturning
Axminster Woodturning 115mm Soft Jaws
SKU: 102166
£28.78
£23.98 Excl. VAT
  • Create custom designed jaws
  • Easy to machine with standard turning tools
  • Suitable for GK100, SK100 and SK114 chucks
  • Excellent addition to your workholding system
  • Non-marking can be used on delicate surfaces
  • Made in the UK from high quality glass filled nylon
The Axminster Woodturning Chuck Soft Jaws allow you to create your own custom-designed jaws. Easy to machine to shape using standard wood turning tools. A sharp, flat scraper works particularly well. These jaws are easy to use and will fit the GK100, SK100 and SK114 chucks. Some care is required when using, but follow some simple guidelines and you will find these an excellent addition to your work holding system. Other than being able to make custom jaws, these are also non-marking, suitable for delicate surfaces.
Made in the UK from high-quality glass-filled nylon. As with all the Axminster Woodturning dovetail jaws, they simply bolt onto the Accessory Mounting Jaws.
Made in Britain Yes
Jaws For 100mm Chuck Yes
Jaws For 114mm Chuck Yes
Intended Use Allows you to create your own custom designed woodturning jaws.
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511065769
