{"product_id":"axminster-woodturning-4-prong-drive-centre-27mm-parallel","title":"Axminster Woodturning 4 Prong Drive Centre - 27mm Parallel","description":"\u003cp\u003eThe Axminster Woodturning 4-Prong parallel drive centre was initially designed to be used in the central bore of the Axminster Woodturning SK100 Dovetail Jaws Type C the C jaws. However, it can be gripped in any suitable lathe chuck able to grip the 27mm diameter mounting. It has principally been produced for those lathes that do not have a hollow headstock, but can also be used for those combined jobs where spindle turning is necessary before mounting the workpiece in the chuck.\u003c\/p\u003e\u003cp\u003eThe centre point helps alignment. Place the point on the centre mark of your workpiece. Give the end of the drive a sharp tap with a mallet rather than using your lathe’s tailstock to push the drive home. This method removes any unnecessary pressure on your lathe’s bearings.\u003c\/p\u003e\u003cp\u003eMounting diameter is 27mm.\u003c\/p\u003e","brand":"Axminster Woodturning","offers":[{"title":"Default Title","offer_id":54115771089243,"sku":"410052","price":11.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/410052_xl.jpg?v=1789756692","url":"https:\/\/www.axminstertools.com\/products\/axminster-woodturning-4-prong-drive-centre-27mm-parallel","provider":"Axminster Tools","version":"1.0","type":"link"}
