{"product_id":"axminster-woodturning-deluxe-bowl-sanding-kit","title":"Axminster Woodturning Deluxe Bowl Sanding Kit","description":"\u003cp\u003eBefore applying a surface finish to your bowls, it is desirable to leave a surface without any visible sanding marks. This can be difficult using normal methods and all too often, tell tale rings are left to spoil your best efforts for a perfect finish. One of the best ways of eliminating this problem is to use a rotating sanding pad driven by the rotation of the lathe. By working through different grit types starting with the coarsest and applying light pressure, you can achieve a surface well prepared for the finish of your choice. The Axminster Woodturning Deluxe bowl sanding kit contains two 70mm pads and two 50mm pads and a comfortable cushioned grip handle with an adjustable head for easy access to your work. \u003cspecial id=\"22\"\u003e\u003c\/special\u003eN.B. Do not use heavy pressure or you will simply generate excessive heat which in turn could lead to the deterioration of the sponge pad.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e The abrasive discs will need to be purchased separately.\u003c\/p\u003e","brand":"Axminster Woodturning","offers":[{"title":"Default Title","offer_id":54117199806811,"sku":"951142","price":53.58,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/951142_xl.jpg?v=1789764772","url":"https:\/\/www.axminstertools.com\/products\/axminster-woodturning-deluxe-bowl-sanding-kit","provider":"Axminster Tools","version":"1.0","type":"link"}
