{"product_id":"axminster-woodturning-diameter-thickness-calipers-pkt-2","title":"Axminster Woodturning Diameter \u0026 Thickness Calipers - (Pkt 2)","description":"\u003cp\u003eTwo sets of turner's calipers, large or small, covering most measuring situations. Each set contains one double ended pair for measuring wall thicknesses (type 1) and an inside\/outside pair for checking diameters (type 2). In both cases, the two ends of the calipers produce the same setting, allowing measurements to be made without removing the calipers from the work.  If you are working with wet timber, these calipers are perfect as they are stainless steel, therefore corrosion resistant.\u003c\/p\u003e\u003cp\u003eCapacities are:\u003c\/p\u003e\u003cp\u003eSmall set - type 1: 120mm, type 2: 190mm.\u003c\/p\u003e\u003cp\u003eLarge set - type 1: 220mm, type 2: 260mm.\u003c\/p\u003e\u003cp\u003eThese calipers are made in Axminster, UK.\u003c\/p\u003e","brand":"Axminster Woodturning","offers":[{"title":"Large","offer_id":54255655616859,"sku":"720902","price":64.98,"currency_code":"GBP","in_stock":false},{"title":"Small","offer_id":54255655649627,"sku":"720903","price":54.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/720902_xl_6ba92a08-2420-4ed8-86dd-b445a7ee4e7a.jpg?v=1791242192","url":"https:\/\/www.axminstertools.com\/products\/axminster-woodturning-diameter-thickness-calipers-pkt-2","provider":"Axminster Tools","version":"1.0","type":"link"}
