{"product_id":"axminster-woodturning-discovery-gk88-chuck-package","title":"Axminster Woodturning Discovery GK88 Chuck Package","description":"\u003cp\u003eThe Axminster Woodturning Discovery GK88 Chuck Package if the perfect introduction for anyone looking to start woodturning. Encompassing all the basic tools necessary for work holding on the lathe, the package includes an Axminster Woodturning Discovery GK88 Chuck, Dovetail Jaws - Type E, Faceplate Ring, Screw Chuck, Chuck Key and Interchangeable Backplate.\u003c\/p\u003e\u003cp\u003eThe chuck, jaws and accessories are all precision engineered and made entirely in Axminster, UK, to ensure they deliver CNC accurate results. The GK88 chuck features a geared key, stainless-steel body and interchangeable backplate for effective corrosion resistance. These chucks won’t rust, either from condensation in a cold workshop or the sap from green wood. Stainless steel body is machined to exact tolerances for a perfect fit of both jaws and lathe spindle.\u003c\/p\u003e\u003cp\u003eThe interchangeable backplate allows you to keep your chuck body when upgrading your lathe, saving you time and money; simply choose the suitable backplate for your new lathe thread and attach to the chuck body. Upon first purchase of your chuck, choose the correct thread for your lathe.\u003c\/p\u003e\u003cp\u003eThe GK88 Discovery chuck is the smallest in the range; its light and compact size makes it ideal for a variety of lathe models but ideally more suited to small to medium sized lathes. The Dovetail Jaws give a stable and secure hold of your workpiece with both an internal and external grip. Supplied is also a Faceplate Ring to use for mounting bowl blanks onto the chuck before initial turning and a 'one piece' screw chuck; designed to bite into the workpiece, perfect for holding smaller projects.\u003c\/p\u003e\u003cp\u003eThe GK88 chuck features our latest SafetyJaw accessory mounting jaws. Pair the chuck with our great range of 88mm jaws to suit your project needs.\u003c\/p\u003e\u003cp\u003eAvailable in sizes 1” x 8 tpi, 3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 16 tpi and M33 x 3.5mm. The M33 x 3.5mm thread is a universal thread, that combines the standard M33 x 3.5mm thread, allows you to add an ASR Locking Ring as well as grub screws to turn in reverse, all in one thread. Suitable for standard M33 x 3.5mm threads and lathes with an ASR spindle for running in reverse. If want to run in reverse, you require a lathe with an M33 x 3.5mm EURO standard (ASR) spindle and the 109370 ASR Locking Ring (sold separately).\u003c\/p\u003e\u003cp\u003eIf you're looking to take up woodturning, then this kit is the perfect starting point. Providing you with all the tools you need to start working on the lathe and exploring this captivating and creative hobby.\u003c\/p\u003e\u003cp\u003eAll made entirely in our manufacturing facility, in Axminster, UK using CNC technology for accurate results.\u003c\/p\u003e\u003cp\u003eTo ensure the chuck is assembled safely, secure the chuck front to the chuck backplate (threaded insert) using the 4 x M6 x 25mm screws and ensure they are tightened to 12NM (Newton-Metres). Please ensure the 2 x M5 Grub Screws are tightened to 2NM.\u003c\/p\u003e","brand":"Axminster Woodturning","offers":[{"title":"1 x 8 tpi","offer_id":54255656632667,"sku":"720939","price":174.98,"currency_code":"GBP","in_stock":false},{"title":"3\/4 x 16 tpi","offer_id":54255656665435,"sku":"720941","price":174.98,"currency_code":"GBP","in_stock":false},{"title":"M33 x 3.5mm","offer_id":54255656698203,"sku":"720942","price":174.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/720939_xl_2ced2dde-135f-41e2-a65a-d6ed007cf874.jpg?v=1791242195","url":"https:\/\/www.axminstertools.com\/products\/axminster-woodturning-discovery-gk88-chuck-package","provider":"Axminster Tools","version":"1.0","type":"link"}
