Axminster Woodturning have recreated some of our most popular jaws in a smaller size to accommodate the Discovery GK88 chuck.
The Axminster Woodturning Gripper Type H Jaws are ideal for smaller hollow form and similar pieces. The jaws feature serrations on the inner and outer gripping surfaces. This particular design offers a super strong on end grain and in green timber. The depth of the jaw adds to the gripping power.
Although ideal for smaller hollow form and similar pieces, as with all the Axminster chuck jaws, versatility comes as standard. The external grip is 55mm, the internal 40mm. These diameters are when the jaws are a true circle. However, the chuck allows a wide range of movement to accomodate any deviation. If necessary, it can grip internally 35mm to 60mm and externally 50mm to 75mm.
These jaws are designed to fit the GK88 chuck and will simply bolt onto the Accessory Mounting Jaws. All made entirely in the UK.
Please note: the Axminster Woodturning Discovery GK88 range of jaws are compatible with the Discovery GK88 Chuck. They are also compatible with the Discovery GK100, SK100 and Evolution SK114 Chucks, providing the Accessory Mounting Jaws are used (106818).
Intended Use For gripping hollow forms or unseasoned wood during woodturning.
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511137213
