{"product_id":"axminster-woodturning-discovery-gk88-pen-jaws","title":"Axminster Woodturning Discovery GK88 Pen Jaws","description":"\u003cp\u003eAxminster Woodturning have recreated some of our most popular jaws in a smaller size to accommodate the Discovery GK88 chuck.\u003c\/p\u003e\u003cp\u003eThe Axminster Woodturning Pen Jaws allow you to drill pen blanks with confidence, knowing the result will be accurate and centred every time.\u003c\/p\u003e\u003cp\u003eDrilling a pen blank can be tricky, the hole needs to be central, straight and round. While various jigs are available for doing the job on a pillar drill, by far the best method is to do the job on the lathe.\u003c\/p\u003e\u003cp\u003eThe Axminster Woodturning Pen Jaws are 42mm deep and can accommodate either round or square blanks from 16mm upwards. The internal profile ensures a secure grip, even if the pen blank is not quite square. Using the jaws in your chuck and mounted on your lathe ensures the blank and the drill bit are centred on the same axis. You also have control of the speed of rotation and the feed speed of the drill bit. Advance the bit steadily and retract frequently to clear the waste. Once the jaws are fitted to your chuck you can drill batches of blanks to help speed up pen production.\u003c\/p\u003e\u003cp\u003eThese jaws are designed to fit the GK88 chuck and will simply bolt onto the Accessory Mounting Jaws. All made entirely in the UK.\u003c\/p\u003e\u003cp\u003ePlease note: the Axminster Woodturning Discovery GK88 range of jaws are compatible with the Discovery GK88 Chuck. They are also compatible with the Discovery GK100, SK100 and Evolution SK114 Chucks, providing the Accessory Mounting Jaws are used (106818).\u003c\/p\u003e","brand":"Axminster Woodturning","offers":[{"title":"Default Title","offer_id":54118530515291,"sku":"111994","price":49.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111994_xl.jpg?v=1789784537","url":"https:\/\/www.axminstertools.com\/products\/axminster-woodturning-discovery-gk88-pen-jaws","provider":"Axminster Tools","version":"1.0","type":"link"}
