These stepped jaws are similar in design to engineer’s chuck jaws. They present a solution to many workholding situations such as gripping drills or dowels and other small workpieces. CNC machined here in Axminster from high quality aluminium they fit onto your existing accessory mounting jaws in the same way as all our other jaw offerings. Each set has a 3mm minimum capacity in the centre, then steps at radii of 17mm and 34mm. The heights of th
Axminster Woodturning
Axminster Woodturning Discovery SK100 Chuck Package M33 x 3.5mm (T38U) Axminster Woodturning Internal & External Aluminium Step Jaw Set
| EAN Barcode | 5052511124374 |
