Axminster Woodturning
Axminster Woodturning Evolution SK114 Chuck Only
SKU: 720951
£259.98
£216.65 Excl. VAT
  • Manufactured entirely in Axminster, UK
  • Square key for positive location and extra torque
  • Stainless steel body for maximum corrosion resistance
  • Direct threaded chuck body ensures concentricity
  • CNC manufacturing for superb accuracy
  • Supplied with a chuck key
  • Fitted with SafetyJaw accessory mounting jaws
  • 114mm (4.5) diameter
  • Lifetime guarantee
More than thirty-five years ago, Axminster produced and marketed one of the world's first four jaw self centring chucks for woodturners. Over the years, much of the development has come from the feedback and input of professional woodturners. With over three decades of experience in production and design, we believe these latest chucks are very best on the market today. Manufacturing of the Evolution chucks, jaws and accessories is done entirely in our production facility here in Axminster.
The Evolution SK114 features a super-slim 114mm (4.5) diameter stainless steel body incorporating our SafetyJaw accessory mounting jaws. The ultra-compact design keeps the workpiece as close as possible to headstock of your lathe to lessen the load on the bearings and prevent unwanted vibration during heavy stock removal. The longer accessory mounting jaws increase the contact area within the slide ways of the chuck, further minimising vibration during use. The Evolution is fully compatible with all accessory jaws. All you need to do is choose the chuck thread to suit your lathe.
Made entirely in Axminster, UK.
Supplied with a chuck key.
Note: 720953 - M33 x 3.5mm chuck is suitable for standard M33 x 3.5mm threads and lathes with an ASR spindle for running in reverse. It has an ASR groove machined on the extended chuck body, which can be used in conjunction with the 109370 ASR Locking Ring (sold separately). This secures the chuck onto the lathe, allowing the lathe to run safely in reverse. If want to run in reverse, you require a lathe with an M33 x 3.5mm EURO standard (ASR) spindle.
To ensure full compatibility with the SK100 range of jaws when using the SK114, we recommend fitting the SK100 accessory mounting jaws (106818).
Thread Size 1 x 8 tpi
Intended Use Plays a crucial role in securely holding the workpiece on a lathe
Web Attribute Set Woodturning Chucks
EAN Barcode 5052511139309
