50mm diameter faceplate is CNC-produced for maximum accuracy and perfect balance. The timber mounting holes are fully countersunk on the rear face and lightly countersunk on the front face to ensure proper seating of the timber; circular grooves are provided to aid the centring of the blank on the plate. Please note that the 50mm faceplate is available with the 3/4
Axminster Woodturning
Axminster Woodturning Faceplate 50mm - 3/4" x 16 tpi
| Made in Britain | Yes |
| Thread Size | 3/4 x 16 tpi |
| Intended Use | Plays a crucial role in securely holding the workpiece on a lathe. |
| Web Attribute Set | Live Tailstock Centres |
| EAN Barcode | 5052511022168 |
