This simple rack for your chuck jaws helps to keep the jaws organised, stored safely and to hand when needed. It is so much easier to work if your accessories are readily accessible rather than rummaging around in a box. The 4 slots at 80mm centres take a set of jaws fitted to mounting jaws. Made from 2mm thick steel it has a tough painted finish. The rack accepts all jaws from the Axminster Clubman SK80, Axminster Clubman SK100, Axminster Evolution SK114 and previous Axminster chucks.
Axminster Woodturning
Axminster Woodturning Jaw Rack
| Overall L x W x H | 320 mm x 14 mm x 91 mm |
| Web Attribute Set | Miscellaneous Woodturning |
| EAN Barcode | 5052511100682 |
