Two sets of turner's calipers, large or small, covering most measuring situations. Each set contains one double ended pair for measuring wall thicknesses (type 1) and an inside/outside pair for checking diameters (type 2). In both cases, the two ends of the calipers produce the same setting, allowing measurements to be made without removing the calipers from the work. If you are working with wet timber, these calipers are perfect as they are st
Axminster Woodturning
Axminster Woodturning Large Diameter & Thickness Calipers - (Pkt 2)
| EAN Barcode | 5052511138173 |
