This strong 2mm thick, wall mounted steel rack keeps your woodturning lathe centres neatly organised. Their sharp points and sharp edges are out of harm’s way and safe from potential damage. It is so much easier to work if your accessories are in full view and to hand. The 6 holes take any 2MT centre. The rack has a tough painted finish and is pre-drilled for wall mounting. Size: L 320mm x W 55mm x H 35mm.
Web Attribute Set Miscellaneous Woodturning
EAN Barcode 5052511123810
