Tapered sleeves suitable for reducing the Morse taper on the tailstock or headstock of your lathe. These adaptors are intended primarily for large diameter drill bits or lathe centres. In certain instances male fittings may need to have a tang formed on the non-tapered part of the fitment (at the very end) so that they fit neatly into the adaptor.
Morse Taper 3MT to 1MT
Web Attribute Set Miscellaneous Woodturning
EAN Barcode 5052511042388
