This 75mm diameter mounting plate screws directly onto the top of an Axminster tool post, in place of the tool rest. It allows you to mount work for additional embellishments, carving, drilling, finishing etc. Like the rest of the Axminster Woodturning range, quality is the result of precision CNC machining. It features concentric circular grooves to help centre the blank on the plate. A slight countersinking of the top of the holes on the front face helps to ensure proper seating of your workpiece.
Axminster Woodturning Mounting Plate For Tool Posts - 75mm
| Made in Britain | Yes |
| Intended Use | Enables you to mount woodturning work for decoration or carving. |
| Web Attribute Set | Woodturning Lathe Accessories |
| EAN Barcode | 5052511099559 |
