These inserts fit into the 50mm Axminster SK100 O’Donnell Dovetail Jaws. Held in place by four cap head screws they are relatively quick to fit. These inserts change the gripping range of the 50mm jaw to that of the 38mm O’Donnell jaw.
The 38mm insert expands into a 50mm dovetail recess and contracts onto a 35mm dovetail or 28mm spigot. The range of movement of the Axminster chuck offers an external grip between 46mm and 60mm, internal dovetail 34mm to 51mm and spigot 24mm to 36mm. These can only be used in conjunction with the 50mm O’Donnell jaws. Made from stainless steel to protect against corrosion.
These jaws are suitable for GK100, SK100 and SK114 Chuck.
Proudly made in the UK
Made in Britain Yes
Jaws For 100mm Chuck Yes
Intended Use For creating dovetail recesses or spigots during woodturning
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511008421
