{"product_id":"axminster-woodturning-odonnell-dovetail-jaws-3-in-1-set","title":"Axminster Woodturning O'Donnell Dovetail Jaws 3-in-1 Set","description":"\u003cp\u003eThe O'Donnell Jaw 3 in 1 package comprises a 50mm O’Donnell Dovetail jaw along with both 38mm and 25mm O’Donnell inserts. Made from stainless steel to protect against corrosion, the inserts fit inside the 50mm jaws, each secured with a cap head screw, making fitting and changing simple. The set gives you all three sizes, 25mm, 38mm or 50mm, by simply undoing the screws and sliding the inserts in or out. Supplied as a complete set of three jaw sizes with four hex head cap head screws and a hex wrench. The jaws and inserts are available separately, but there is a price advantage if you buy them all together. Suitable for GK100, SK100 and SK114 chucks only. As with all Axminster Woodturning dovetail jaws they simply bolt onto the Accessory Mounting Jaws.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eAxminster 50mm(2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) O’Donnell Jaws\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eDesigned to give access around the jaws for close-in tool work. With a deep recess for holding long spigots and giving rock solid mounting when turning a long way from the headstock without tailstock support. The jaws are also dovetailed both inside and outside on the lip. Nominal external dovetail grip is 50mm. Drilled and threaded to accept additional jaw inserts to convert to smaller jaw diameters.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eAxminster O’Donnell Jaw inserts\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eTwo sizes of inserts for use with the 50mm Axminster O'Donnell jaws. The larger set has a parallel grip of 25mm, will close onto a dovetail spigot of 32mm or will open out into a dovetailed recess of 46mm diameter.\u003c\/p\u003e\u003cp\u003eThe smaller insert set has a parallel grip of 13mm, will close on an 18mm spigot or expand into a 32mm dovetailed recess. The O'Donnell jaws and inserts offer a great range of workholding options enabling better access to the rear of the work piece, especially when turning bowls.\u003c\/p\u003e","brand":"Axminster Woodturning","offers":[{"title":"Default Title","offer_id":54235578696027,"sku":"718321","price":164.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/718321_xl.jpg?v=1790945240","url":"https:\/\/www.axminstertools.com\/products\/axminster-woodturning-odonnell-dovetail-jaws-3-in-1-set","provider":"Axminster Tools","version":"1.0","type":"link"}
