The Axminster Woodturning Pen Assembly Press allows you to put your pen or pencil together in an easy-to-use and above all controlled way. The Pen Press offers reliability, accuracy and control to press your pen parts together. The Pen Press takes large pens up to 19mm in diameter and a maximum length of 225mm. It features a strong arm with an ergonomic handle. If you have spent time using a vice or a clamp to assemble your pens, then this will be a revelation, it presses straight and precise, making assembly a pleasure.
Note: On first use, reposition the handle as shown in the online manual. Full assembly guidance can be found in the Information Downloads.
