If you own a woodturning lathe and have always wanted to try the fascinating art of pen turning; this package contains all you need to begin.
The package comprises; a set of 5 small HSS turning tools, a pen mandrel, a pen drill, barrel trimmer and 4 of popular twist pen kits, along with 4 different pen blanks,
The tools offer complete control when turning smaller items such as pens. The pen mandrel, barrel trimmer and HSS pen drill are all you need to mount the blanks on your lathe and begin turning. The kits are excellent quality, straightforward to turn and construct. Each pen kit includes instructions and a refill to provide smooth, trouble-free writing. Bushes supplied with the pen mandrel are the correct diameter for these kits. Two acrylic, plus an oak and a walnut blank, will give you experience in turning different materials.
By the time you have finished the kits, you will be an experienced pen turner. Choose 1MT or 2MT to suit your lathe
Contents:
5 turning tools with HSS blades and well-shaped hardwood handles. Overall length is approximately 190mm supplied in a wooden box.
3.2mm(1/8") and 6.3mm(1/4") gouges
1.6mm(1/16") parting tool
6.3mm(1/4") domed scraper
6.3mm(1/4") skew chisel
Axminster Evolution Series Pen Mandrel
Barrel Trimmer
HSS Pen Drill 7mm
Artisan 10 Karat Gold Twist Pen Kit
Artisan Chrome (A Logo) Twist Pen Kit
Artisan Chrome (Black Clip) Twist Pen Kit
Artisan 24 Karat Gold Twist Pen Kit
White Lightning Acrylic Pen Blank
Classic Acrylic Pen Blank
Walnut Pen Blank
Oak Pen Blank
Drill Bit Required 7 mm
Bushing Set Order No. 8.5mm O/D (as supplied with mandrel) (100793)
Minimum Blank Size 16 mm x 16 mm x 112 mm
Morse Taper 1 MT
Refill Order Number 310492
Colour Mixed Web Attribute Set: Project Kits
EAN Barcode 5052511125692
