The Ring Point for the Axminster Deluxe Live Revolving Centre applies pressure to your work over a relatively wide area making it particularly useful for delicate timber or soft wood liable to split. You can adjust the amount of compression to suit the timber. The 8mm diameter matches the Ring Drive Friction centre allowing you to swap your work end over end without losing concentricity. 24mm long.
Made in Britain Yes
Intended Use Plays a crucial role in securely holding the workpiece on a lathe.
Web Attribute Set Live Tailstock Centres
EAN Barcode 5052511067039
