{"product_id":"axminster-woodturning-screw-chucks","title":"Axminster Woodturning Screw Chucks","description":"\u003cp\u003eA screw chuck is a quick and convenient method for mounting a turning blank on your lathe. The central screw is stainless steel with a deep sharp thread for a positive and secure hold. It only requires you to drill a single shallow hole in the blank. Unlike a face plate which requires several screws to attach the timber, a screw chuck has a single central screw. It is ideal for smaller or shallow workpieces, (always assess the suitability for the size of the work).\u003c\/p\u003e\u003cp\u003eThese screw chucks fit into C jaws of an Axminster woodturning chuck. This enables you to turn both the outside and the inside of a bowl without having to remove your Axminster chuck from the lathe. Thus guaranteeing complete concentricity.\u003c\/p\u003e\u003cp\u003eTo fit into the 100mm and 114mm C dovetail jaws.\u003c\/p\u003e\u003cp\u003eFor particularly shallow pieces use a plywood spacer to reduce the effective length of the screw.\u003c\/p\u003e\u003cp\u003eSupplied fitted with an 8mm x 25mm long screw. Two smaller size screws are available separately, useful in making wooden fruit etc.\u003c\/p\u003e","brand":"Axminster Woodturning","offers":[{"title":"Default Title","offer_id":54115920019803,"sku":"810385","price":19.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/810385_xl.jpg?v=1789758215","url":"https:\/\/www.axminstertools.com\/products\/axminster-woodturning-screw-chucks","provider":"Axminster Tools","version":"1.0","type":"link"}
