{"product_id":"axminster-workshop-ad240wl-woodturning-lathe-230v","title":"Axminster Workshop AD240WL Woodturning Lathe - 230V","description":"\u003cp\u003eIf you have ever wanted to take up woodturning, this lathe will meet all your needs and provide hours of turning enjoyment in your workshop. Its compact design and affordable price make it ideal for those with limited space or a tighter budget, and it pairs perfectly with the Perform Woodturning Chuck.\u003c\/p\u003e\u003cp\u003eThe AD240WL woodturning lathe features five spindle speeds, giving a useful range between 700 and 2,800rpm. It has a maximum bowl turning capacity of 240mm diameter and a spindle turning capacity of 440mm between centres.\u003c\/p\u003e\u003cp\u003eThe headstock, bed and tailstock are constructed of heavy cast iron, minimising vibration. The 375W induction motor has more than enough power for the lathe’s capacities and any projects that are likely to be undertaken.  Both the headstock spindle and tailstock barrel take 2MT accessories, with the spindle nose having a 1\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 8tpi thread. The tailstock also has a hollow barrel to enable long hole boring.\u003c\/p\u003e\u003cp\u003eSupplied with Axminster drive and revolving tailstock centres, 75mm diameter faceplate and 150mm tool rest.\u003c\/p\u003e\u003cp\u003eN.B. The distance between centres will vary slightly dependent on the type of centres or accessories used.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePlease note, if you require an EU plug, please ensure you purchase 113504\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Axminster Workshop","offers":[{"title":"Default Title","offer_id":54118432145755,"sku":"107673","price":295.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107673_xl.jpg?v=1789779542","url":"https:\/\/www.axminstertools.com\/products\/axminster-workshop-ad240wl-woodturning-lathe-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
