This bench mounted woodturning lathe offers excellent capacity, capabilities and power. The AD305WL has the convenience of variable spindle speed with electronic control.
Power comes from a 550W DC motor providing full torque across the speed range. The spindle speed range is from 500 to 4,080rpm, with a choice of two belt ratios.
Made almost entirely in cast iron ensuring stability and minimal vibration during operation. The bed of this lathe has a finely ground top surface for smooth tool rest positioning. The spindle nose has a 1 x 8tpi thread and a 2MT taper. The tailstock barrel has a 2MT bore with 50mm of movement and automatic ejection of centres. Quick release levers allow for easy and accurate positioning of tool rest and tailstock. Solid rubber feet help to eliminate vibration.
Please note, if you require an EU plug, please ensure you purchase 113504
Overall L x W x H 970 mm x 280 mm x 440 mm
Power 550 W
Rating Regular Use
Web Attribute Set Woodturning Lathes
EAN Barcode 5052511125371
