{"product_id":"axminster-workshop-ad355wl-woodturning-lathe-230v","title":"Axminster Workshop AD355WL Woodturning Lathe - 230V","description":"\u003cp\u003eThe AD355WL is perfect for those woodturners looking to move up from a smaller lathe, or as a first lathe for the more ambitious newcomer. With a capacity of 510mm between centres (depending on the centres fitted) and with a bowl turning capacity of 355mm, many ambitious projects can be undertaken. Use the Mini Bed Extension to increase your distance between centres to 740mm.\u003c\/p\u003e\u003cp\u003eMade from grey cast iron, the stability and vibration absorbing properties will be much appreciated. Featuring a top quality DC brush motor, with variable speed, three belt ratios and reverse. It has a speed range to suit every project within its capacities. A spindle speed readout helps select the appropriate speed for the job.\u003c\/p\u003e\u003cp\u003eThe headstock has large bearings to support the spindle, a flip-up cover allows easy access to the multi-V belt for speed ratio changing. There is a 24-stop indexing facility, with a spring-loaded indent pin to hold the spindle into position. The spindle thread is M33 x 3.5, allowing many accessories to be fitted. It has a 2MT for centres.\u003c\/p\u003e\u003cp\u003eCam locks secure both the tailstock and tool rest holder, and both are easy to move along the bed.\u003c\/p\u003e\u003cp\u003eMounted on rubber feet and supplied with Axminster drive and tailstock centres, 200mm tool rest, 100mm faceplate and Axminster Workshop Mini Bed Extension.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePlease note, if you require an EU plug, please ensure you purchase 113504\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Axminster Workshop","offers":[{"title":"Default Title","offer_id":54118433358171,"sku":"107701","price":615.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107701_xl.jpg?v=1789779630","url":"https:\/\/www.axminstertools.com\/products\/axminster-workshop-ad355wl-woodturning-lathe-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
