{"product_id":"axminster-workshop-aw1400b-bandsaw-230v","title":"Axminster Workshop AW1400B Bandsaw - 230V","description":"\u003cp\u003eThe Axminster Workshop AW1400B bench mounted bandsaw is designed for the small workshop and easily moved when not in use.\u003c\/p\u003e\u003cp\u003eIt features a strong welded steel chassis with a cast iron table. It will take blades from 4.8 to 9.5mm wide. Bearing blade guides and thrust bearing provide maximum blade control for improved accuracy over similar entry level bandsaws. The top guide blade has a rack and pinion height adjustment, giving a maximum of 80mm depth of cut.\u003c\/p\u003e\u003cp\u003eIt has a direct drive motor and balanced cast alloy wheels. The top wheel is mounted in a welded steel sub frame with blade tensioning and tracking controls conveniently close.\u003c\/p\u003e\u003cp\u003eA single dust outlet port provides efficient dust removal when connected to a suitable vacuum extractor, which must be recommended for increased cutting performance.\u003c\/p\u003e\u003cp\u003eThe machine is supplied with a 6mm x  6tpi general purpose blade made from UK manufactured stock. A selection of different blades are available to suit many jobs.\u003c\/p\u003e\u003cp\u003eAn optional mitre fence is available to fit this bandsaw (sold separately).\u003c\/p\u003e\u003cp\u003eThis is a superb small bandsaw for a hobby or craft workshop or as an additional machine for smaller work.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePlease note, if you require an EU plug, please ensure you purchase 113504\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Axminster Workshop","offers":[{"title":"Default Title","offer_id":54118433489243,"sku":"107710","price":239.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107710_xl.jpg?v=1789779639","url":"https:\/\/www.axminstertools.com\/products\/axminster-workshop-aw1400b-bandsaw-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
