{"product_id":"axminster-workshop-aw140bs-bobbin-sander-230v","title":"Axminster Workshop AW140BS Bobbin Sander 230V","description":"\u003cp\u003eThe Axminster Workshop AW140BS Bobbin Sander is perfect for sanding and refining curves and edges. The bobbin oscillates vertically, leaving a smooth, clean finish which also prevents burning and spreads the wear of the sanding sleeve.\u003c\/p\u003e\u003cp\u003eIt has a cast iron table that tilts up to 45 degrees and locks firmly in place. The 370W motor is quiet in use and slow running as to not burn your work. Dust extraction is via a 50mm port on the rear and should be connected to a suitable vacuum extractor. The sander has a rigid steel frame and cast iron top, which helps to reduce vibration. There is also storage space for spare bobbins.\u003c\/p\u003e\u003cp\u003eThis Bobbin Sander is ideal for crafts and small projects, perfect for small workspaces. Supplied with 19, 23, 35, 42 and 50mm bobbin sizes and abrasives.\u003c\/p\u003e\u003cp\u003ePlease note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePlease note, if you require an EU plug, please ensure you purchase 113504\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Axminster Workshop","offers":[{"title":"Default Title","offer_id":54118527369563,"sku":"111879","price":369.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111879_xl.jpg?v=1789784319","url":"https:\/\/www.axminstertools.com\/products\/axminster-workshop-aw140bs-bobbin-sander-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
