The Axminster Workshop AW140BS Bobbin Sander is perfect for sanding and refining curves and edges. The bobbin oscillates vertically, leaving a smooth, clean finish which also prevents burning and spreads the wear of the sanding sleeve.
It has a cast iron table that tilts up to 45 degrees and locks firmly in place. The 370W motor is quiet in use and slow running as to not burn your work. Dust extraction is via a 50mm port on the rear and should be connected to a suitable vacuum extractor. The sander has a rigid steel frame and cast iron top, which helps to reduce vibration. There is also storage space for spare bobbins.
This Bobbin Sander is ideal for crafts and small projects, perfect for small workspaces. Supplied with 19, 23, 35, 42 and 50mm bobbin sizes and abrasives.
Please note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
Please note, if you require an EU plug, please ensure you purchase 113504
Dust Extraction Outlet 44 mm I.D. / 50 mm O.D.
Power 370 W
Rating Regular Use
Stroke Length 22 mm
Table Height 485 mm
Table Size 375 mm x 375 mm
Plug Fitted UK 3 pin plug
Web Attribute Set Oscillating Spindle Sanding Machines
EAN Barcode 5052511136254
