{"product_id":"axminster-workshop-aw18bds-belt-disc-sander-230v","title":"Axminster Workshop AW18BDS Belt Disc Sander 230V","description":"\u003cp\u003eThe Axminster Workshop AW18BDS Belt \u0026amp; Disc Sander 230V is ideal for detailing, shaping, and finish sanding for those larger projects. It features a 25 x 1,067mm belt and a 150 x 200mm tilting table for profiling and finishing. The 200mm disc abrasive and 190 x 270mm table are perfect for end grain work and fine-tuning angles. Both tilting tables allow for precise detail work and achieving mitres and compounds with ease.\u003c\/p\u003e\u003cp\u003eThe machine includes two 38mm dust extraction outlets for both the belt and disc, a hook and loop sanding disc and belt, and a mitre gauge. It's perfect for working on larger projects that may require a larger sanding capacity.\u003c\/p\u003e\u003cp\u003ePlease note these machines are designed and manufactured for sanding wood and similar materials. It should not be used to abrade or grind metal.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePlease note, if you require an EU plug, please ensure you purchase 113504\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Axminster Workshop","offers":[{"title":"Default Title","offer_id":54118624985435,"sku":"111998","price":199.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111998_xl.jpg?v=1789788372","url":"https:\/\/www.axminstertools.com\/products\/axminster-workshop-aw18bds-belt-disc-sander-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
