{"product_id":"axminster-workshop-aw200bds-belt-disc-sander-230v","title":"Axminster Workshop AW200BDS Belt \u0026 Disc Sander - 230V","description":"\u003cp\u003eThe AW200BDS is a powerful combined 100mm belt and 200mm disc sander. The belt and the disc are driven directly from the motor spindle. As a consequence the machine is much quieter, there are no fiddly drive belts to worry about and does not suffer from a loss of power caused by a drive belt. Both functions feature cast worktables, which pivot from 0° to 45°. A mitre fence is supplied for bevel and compound angle sanding.\u003c\/p\u003e\u003cp\u003eThe belt sanding platen can be used vertically or horizontally or anywhere in between. The machine has a 63mm extraction outlet. A powered fan in the dust outlet port helps produce an airflow around both the belt and disc. When connected to a suitable vacuum extractor almost 100% dust extraction can be achieved. The main body is cast iron, which absorbs vibration and has locating holes with rubber grommets for securing this sander to a workbench.\u003c\/p\u003e\u003cp\u003eThe AW200BDS is supplied with a belt and hook and loop abrasive disc. There is a wide selection of abrasive belts and discs available.\u003c\/p\u003e\u003cp\u003ePlease note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePlease note, if you require an EU plug, please ensure you purchase 113504\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Axminster Workshop","offers":[{"title":"Default Title","offer_id":54118432407899,"sku":"107680","price":210.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107680_xl.jpg?v=1789779567","url":"https:\/\/www.axminstertools.com\/products\/axminster-workshop-aw200bds-belt-disc-sander-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
