The Axminster Workshop AW254SMS Slide Mitre Saw is a versatile and capable machine for the home workshop or light-medium tasks, delivering dependable performance with an excellent balance of quality and value.
Powered by a 1.8kW motor, the saw drives a 254mm blade at speeds of up to 4,500rpm, providing smooth, accurate cuts across a wide range of timber sizes. The soft start motor ensures controlled start-ups, making the saw more comfortable to use in home workshop or residential environments.
The sliding mechanism offers an impressive maximum crosscut capacity of 305mm x 90mm, making it suitable for cutting wider boards and larger workpieces. A mitre range of 52° left to 60° right combined with a bevel range of 45° left and right allows for a wide variety of angled, mitre and compound cuts. Maximum capacities include 215mm x 90mm mitre cuts at 45° and 215mm x 40mm bevel cuts at 45°, giving excellent versatility for joinery, trim work and general woodworking projects.
Achieving precise cuts is easy, thanks to the integrated Class 2 laser guide, clearly indicating the cutting line for quick and precise alignment. A workpiece clamp helps hold material securely against the fence to improve safety and accuracy, while the spindle lock allows for fast and straightforward blade changes.
The saw also features a depth stop, enabling controlled trenching cuts, ideal for housing joints and other woodworking applications.
Designed with practicality in mind, the AW254SMS Slide Mitre Saw includes integrated carry handles for easy transport around the workshop or convenient storage when not in use. A dust collection bag is supplied to help keep your workspace cleaner during operation.
Supplied with a 60-tooth, negative rake contract grade blade, the Axminster Workshop AW254SMS Slide Mitre Saw is ready to tackle a wide range of cutting tasks straight out of the box.
Please note, if you require an EU plug, please ensure you purchase 113504
Bevel Angle Range 45 - 0 - 45
Dust Collection Dust Bag Supplied
Mitre Angle Range 52 - 0 - 60
Overall L x W x H 870 x 1,120 x 615 mm
Rating Regular Use
Spindle Lock Standard Feature
Table Size 470 x 370 mm
Blade Diameter 254 mm
Sound Power Level LwA [Uncertainty K] 92 dB(A)
Corded or Cordless Corded
Blade RPM 4,500 rpm
Sound Pressure Level LpA [Uncertainty K] 104 dB(A)
Motor Power 1,800 W
Plug Fitted UK 3 pin plug
Web Attribute Set Mitre Saws Mains Powered
EAN Barcode 5052511142170
